08-05-2016 06:48 AM
Hello All,
I am using MPMC in EDK for one of my project.I have created Microblaze system with PLB based.
Taken one MPMC IP core from EDK IP catalog and connected this to PLB bus of Microblaze.
Netlist is properly generated in EDK but when I implement design in ISE I get following error
ERROR:Place:866 - Not enough valid sites to place the following IOBs:
IO Standard: Name = LVCMOS25, VREF = NR, VCCO = 2.50, TERM = NONE, DIR =
BIDIR, DRIVE_STR = 12
rzq
ERROR:Place:382 - The placer was unable to find a feasible solution for the IOBs
in your design. This is possibly due to SelectIO banking constraints.
ERROR:Place:418 - Failed to execute IOB Placement
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
Design is not getting complied.
How should I resolve this issue.
Vinayak Kumthekar
08-07-2016 08:21 AM
Please refer to http://www.xilinx.com/support/answers/34635.html
Praveen
08-07-2016 11:23 PM
Hi Praveen,
I have instantiated EDK module in my ISE top module.
If I reduce number if Input and Outputs or change to bigger FPGA device or if I comment all signals in UCF then also this error in occurring.
@pvenugo wrote:
Praveen
Vinayak
