MicroBlaze and 10GE
I'm looking into integrating 10G Ethernet with the MicroBlaze on the VC709 development board. I'm only planning to run a slow RPC service on the MicroBlaze, so the 10Gigabit speed is needed due to 10G Aurora running on the same MGT Quad. I'm planning to use the AXI 10GE Subsystem, DMA and AXIS interconnect cores. The AXIS interconnects are expected to be used for rate/width conversion between the MicroBlaze (32-bit @ 100MHz) and the 10GE subsystem (64-bit @ 156.25MHz).
Is this possible with exisiting xilkernel drivers (Vivado 2015.2)? I assuming the lwIP driver is my only option.
Is the reference project "xapp1026" the best reference design for this effort?
Any additional advise would be appreciated.
Thanks!
Does the xilKernel support the 10G Ethernet Subsystem (v3.0)?
Are there any design approaches to running the AXI 1G/2.5G Ethernet Subsystem on a pre-configured 10G Aurora 64B/66B MGT bank?
Any update on using LWIP and 10gb subsystem?
up!!!
The driver support in accord to https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842485/Linux+AXI+Ethernet+driver has been implemented only on 2017.1.
