Anonymous
Not applicable
MicroBlaze as component, degug problem
I have trouble debugging my application running on MicroBlaze as a component. When I try to debug I get the message that it can't connect to the target and suggests that MDM might not be running. I'm pretty sure that the clock is connected correctly. When I run MicroBlaze directly in EDK then it works. Any suggestions?  Are there any ref.design I could look at?
