08-10-2020 02:01 AM
Hello All.
I am working with microblaze softcore processor,Using microblaze i created my block diagram after genereating a bitstream file i laaunched sdk.And my block diagram is below.Now by using SDK i want write a program that in interuupt mode by using gpio ip (pressing push button)
i want to send ascii commands using(Axi uartlite ip).Can any one tell me how to do it and where i can get reference.
Thanks in advance.
Best Regards
SUNKU
08-23-2020 08:12 AM
Hi @jsunku ,
There is no direct reference example, but you can give a try with some steps.
In the design I see that the interrupts on the GPIO are not enabled. So enable the interrupts and connect the interrupt line to the Microblaze interrupt port.
Try out with a simple example keeping the gpio_interrupt example as reference.
