Microblaze lockstep
in my project I would like to use Microblaze (Vivado 2019.1) in LockStep hidden slave configuration. In normal configurtion (no lockstep) I have debug port and everything is OK (I can debugging in SDK).
No lockstep debug port is workingNo lockstep debug port is working
When I switch configuration Lockstep Interface from none NONE to LOCKSTEP HIDDEN SLAVE Debug port disappear.
No lockstep with debug portNo lockstep with debug portIt is ok? In Hidden lockstep configuration I cannot debugging?
Thank you for any information
Milan
In my first question was mistake in pictures. Now is corect.
no_lockstep.pngNo lockstep debug port is working
mb_lockstep.pngNo lockstep with debug portIt is ok? In Hidden lockstep configuration I cannot debugging?
Milan
