Microblaze
Hello Everyone,
how to write a led blinking code in c programing language in spartan 6 family using microblaze?
hbucher
vikrantthakur@35515
You have to check if your device is supported by Vivado (I believe it is not).
In this case, you'd have to go with ISE. Here is something I found on youtube
https://www.youtube.com/watch?v=zc42Gz2y2xs
ashok.cheepati
1. You just create application project in sdk like simple hello world.
2. In the main.c initialize the gpio signal as Gpio_Initialize(&axi_pmod1, 0);
3. Set the direction of gpio as input or output which you will get inside XGpio_Initialize function.
4. write a small counter program and pass the counter value to LED's or you can pass constant value using IOWR function.
Best Regards,
--Ashok
