markalbers
Migrate Vivado project from ZedBoard to MicroZed
I want to migrate an Vivado project from ZedBoard to MicroZed. First question, is this possible? I tried to change the "Project Device" under "Project Settings" and adjusted my in-/output constraints. Is this all? The result is, tested with a small petalinux projekt created with that hardware description booting from SD card, the red user led flashes once very short and the done led never comes up. So I think the bitstream could not be loaded.
markalbers
I was switching to the MicroZed 7020. But there were some board specific setting in the ZYNQ PS (main memory ...) which had to be adjusted.
bhfletcher
ZedBoard has a 7020 device. MicroZed comes in both a 7010 and 7020. Are you switching to the MicroZed 7020?
If you used a board definition to create the original hardware platform, then you will have to update the associated board definition.
Honestly, I think it may be easier to start with the MicroZed-specific PetaLinux BSP and then migrate your specific pieces. The MicroZed PetaLinux BSPs are located here:'
http://microzed.org/support/design/1519/10
Bryan
markalbers
