blp4
Need help for address allocation in a MicroBlaze project
i am using Virtex-5 XC5VFX70T for a MicroBlaze project,and i get some problems.
 i add a 256k bram  connected to LMB bus as follows
MEMORY
   ilmb_cntlr_dlmb_cntlr : ORIGIN = 0x00000050, LENGTH = 0x0003FFB0
then,in my C code,a 2048x40 matrix is defined as follows
Xfloat32 mat[2048][40];
when i debug my program,i find that this matrix is allocated to an address 0xfffb2d20 which doesn't exist in the project.
Plz anyone help me solve this problem,thx.
pafisep
Can you write and read from the matrix?
If the answer is yes, the matrix is at that address, from the software perspective.
If you are using Linux  ( not uCLinux ) you have the virtual memory support running...
See how virtual memory works on a textbook,.
My best regards
Paulo Ferreira
