jesusmgonzalez
Nonvolatile user preferences storage Zynq
Although I've been digging out through all the posts and web sites, I still can't figure out how could I
storage, permanently, some user data and preferences in Zynq, for standalone applications.
All what I would like to do is to storage some bytes, in some kind of EPROM type memory. After one
user session, probably some of these bytes would be changed, and rewritten again to this portion
of memory.
I know I can't use PL part of the Zynq system, because when system is shutting down, input supply
is phisically disconnected. So, I guess the only kind of memory I could use for this application is
Flash memory, but after some testing apps, all the information is erased after image flash-programming.
Is there any option for this?
Thanks in advance,
rjsefton
Serial EEPROM is ideal for storing small amounts of data like this. Small, cheap, and the interface is simple. You could hang it off of the PL or PS.
muzaffer
do you have qspi on your board ? That's something you can use. Or attach an i2c flash to the processor especially if you are storing info about how/what to program to pl.
jesusmgonzalez
Thanks for your quick support and answers.
I'm currently working on a project where the main board is Enclustra Mars ZX3. Reading the user guide,
it states that performs a small EEPROM memory to store, for instance, serial number and other
parameters.
This board also includes a Q-SPI flash memory, but, Could I use this memory, instead of EEPROM, for
my purpouses? As I have understood, flash memory (external proc) performs a complete erase of memory map for
consistency tasks. Is this correct?
Thanks in advance,
trenz-al
it depends how you access the spi flash. it is possible to use some sector from TOP  of the spi for paramater storage
of course then you can not do bulk erase only sector erase laters
