manh_et2
Parrallel execution of IPs who connect to bus OPB???
Hello ACEs,
In my design, I have IP CAN and IP I2C who connect to the uController via bus OPB. I wonder if these 2 IPs runs parallelly or only sequently?
Thank you all.
barriet
The peripherals will be implemented in parallel and can run independently. Note that with a shared bus structure, only one of these peripherals will be able to be accessed at a given time by a given processor access.
I wouldn't expect this to be an issue for slower speed peripherals such as CAN and I2C.
Cheers,
bt
manh_et2
I know that we can implement several MicroBlaze cores in one FPGA and connect them by using the bus FSL, but I wonder if we can add some bus OPBs respectively correspond to each MB core?
barriet
Here is an example with 2 MicroBlaze processors, each with its own OPB bus and peripheral set:
Note that they share a common clock and reset (I just did that for simplicity)
What is also possible but not implemented there was a pair of FSL bridges between the 2 MicroBlaze processors.
You may also find these useful:
http://www.xilinx.com/bvdocs/whitepapers/wp262.pdf (Designing Multiprocessor Systems in Platform Studio)
http://www.xilinx.com/bvdocs/appnotes/xapp996.pdf (Dual Processor Reference Design Suite)
Cheers
Message Edited by timpe on 10-30-2007 10:36 AM
yadav.jvk
I am using I2C controller in the Spartan3E Dev. Kit. I made the I2C clk and data as external outputs. The code statements after the I2C templates(ex:  XIic_Initialize, XIic_SetAddress) are not executed i.e it seems processed hanged. can anyone please help me int this regard.
yadav.jvk
If you have worked on I2C controller, can you help me!.
When iam using I2C templates like  XIic_Initialize, XIic_SetAddress the statements after these templates are being executed?.
what could be the problem?
Anonymous
Not applicable
Did you find a good way to get an I2C controller to work?  I am just starting out in FPGA design and so far all I know how to work are the initialize and selftest on a ML405.
Brian
yadav.jvk
Hi Brian,
I left the I2C design module implemented in microblaze becuase we got a VHDL module for the same. BUt i can give a tip for the same. After you complete the design in EDK,
1) open a new project in ISE and add a copy of the system_stub.vhd, system.ucf of the EDK project to your ISE project and add the edk proect
    (*.xps).
2) Write a top wrapper module, which has instantiation of system_stub.vhd,
3) The I2C clk and data signals are "inout", hence we cann't probe them. so declare two local signals and  port map them to I2C clk and
     data.
4) Use a IOBuffer with i/p as I2C signal and o/p them to probe.
By this way you can check I2C signals. I hope it would help you.
JVK
