zvivered
Petalinux 2018.3: BOOT ZCU111 from SD Card
The pre-built folder contains BOOT.bin
Can you please explain how this bin file was created ?
It seems this bin contains a linux file system.
How can I boot from SD and have a file system which is R/W ?
Thank you,
Zvika
stephenm
The BOOT.BIN file contains the following
  • bitstream
  • uboot executable
  • atf executable
  • pmu firmware executable
  • fsbl executable
This file is created in the petalinux-package command, which run bootgen under the hood.
zvivered
Is it possible to have a linux file system on the SC card ? How ?
Till now I managd to launch a linux kernel located on the SD. Where and how should I locate a R/W file system ?
Thank you,
Zvika
