manh_et2
Point-to-point connection PowerPC-MicroBlaze???
Hi all,
I'm searching the solution for connecting (point-point) between one PPC and one MB.
I know that we can use the bus FSL via the bridge FCB2FSL in PPC but there is the bus FCB only in Virtex 4.
I'm currently searching for the solution for all the family Virtex.
Thank you.
golson
The Microblaze does not need a bridge.  You add a FSL peripheral to a microblaze using the Create or Import Peripheral tool.  I don't think
you will find IP to add this in the system view.   Take a look at then menu item (i think under hardware) Create or Import Peripheral Tool.
or APPNOTE   http://www.xilinx.com/support/documentation/application_notes/xapp529.pdf
golson
manh_et2
Thank you,
I know that FSL is dedicated to MicroBlaze. And the appnote I've also read, but the design is version 6.1 and 6.2, I couldn't open it.
Thank you anyway for your suggestion.
golson
If you need to use a FSL it is not hard to create.  I used the above app note and created a FSL in version 10.1.  I did not need the old project to do this.
But the old project files can be used to help figure out what needs to be done.
