Private Watchdog reset
  Hello,everyone!
  I have impletement AMP system cited by XAPP1079. I want to implement only one CPU reset through setting the register slcr.RS_AWDT_CTRL{1,0} = 1. I also unlock and lock slcr register so the value of RS_AWDT_CTRL register has changed 0x3 not 0x0.But now it still reset both CPUs and PL.
  What should I do to reset only CPU0 or CPU1 through private watchdog?
  Thanks for your help.
Re: Private Watchdog reset
i am having the same issue.
Did you find a solution?
regards,
Max
