jingbinzhang
Problem integrating EDK project in ISE 9.1
hello,all
      i have built an edk project(based microblaze) . Because my application c code is very big,when generating linker script ,i put some big sections into the ddr and others into bram in microblaze.finally,it displays the results through rs232.
      for now,i want to try to import the EDK Project with microblaze as Sub-system into a ISE project and i use the cammand h "export to project navigator",then it generate a system.ise file.but,when i put the .system_stub.bit,system_stub_bd.bmm and my_project.elf(software bits) files into the board ,it does not work well.
       however,if i replace the my_project.elf to TestApp_Memory.elf (linking script in bram not ddr),it works well.
       who can tell me the reasnon ? what can i should do?thank you very much..
