hamdi436
QEMU SDK
Hello !!
I have a question about using qemu SDK , when using qemu in sdk it emulate both PS and PL ?? or just PS ??
I am talking about qemu provided by sdk not the one from petalinux or building from source.
THANKS
stephenm
The QEMU in SDK/XSCT would be the same as the one in petalinux, or built from sources.
You can emulate IP in the PS and the PL. If you want to emulate the IP in the PL, then you can use a co-simulation
with the Vivado simulator.
hamdi436
Thanks, what do you mean by cosimulation with vivado simulator ? is that a cosimulation with qemu , and if it is the case , do you have a document or a link that i can follow to see that. thanks a lot
stephenm
hamdi436
hi @stephenm ,
I already did this example , now i have a simple adder example written in systemc/tlm , the example is for the zynq 7000, i am trying use the systemc-cosim-demo to add  the adder but still not acheiving the goal, so can you advice me how to do that , may be you have some ideas that i can follow or search ? thanks a lot
