peterpan007
RT Application on Cortex R5 controlled by Hypervisor on Ultrascale+ zcu102
Hi all,
I have a design decision question. I would like to have a Non-RT application on APU and an RT application on RPU of a ZCU102 Ultrascale+ both managed by a hypervisor. But as mentioned in the UltraScale Design methodology, Cortex-R5 does not support virtualization. Does that mean that I cannot have control over RPU from the Xen-RT Hypervisor? What would be the design flow if two RT and non-RT application should be controlled by a hyperviosor?
P
gudishak
Hi @peterpan007
We do not have solution directly to run application on RPU. But you can use openamp to download the firmware using Remoteproc procedure. Refer UG1186 latest document for further
Best Regards
Kranthi
