jordanairbusds
Read Write to SD
Hi all,
I work with a Zedboard and I would like read and write in file to SD card. I use the FatFs library (the library used on the FSBL) but I can't mount the SD card :
rc = f_mount(&fatfs, "0:/", 1)
I have the error code 13 : Not valide FAT volume
Someone can help me please ?
Jo
trenz-al
Format
jordanairbusds
Hi ,
I tried but I still have the same error.
Jo
embeddedcentric
Are you using standalone or linux ? In any case, make sure that the settings in Vivado for the SDO is as in the picture attached.
You can find a compete tutorial on how to use the SD card of Zedboard on the link below. Download the Vivado project at the end of the page and make sure that the hardware configuration for the SD0 is identical to yours. Also chck the .c file to see the proper use of APIs.
Link: http://embeddedcentric.com/data-logging-using-sd-cards/
EmbeddedCentric.com
