Run two Core using share memory on Zynq Ultrascale+
Hello
I try to run 2 Bare-metal application (no Linux involved) each no GPU_53_0 and RPU_5_0 respectively using share memory
for example RPU_5_0 send a serial of number 1234 into a common memory (share by both cores) then APU_53_0 will
goto share memory and get that content (i.e. 1234) then display the value to the console.   Any one have this information
or know how to implement this task please pass along to me.
Your help is greatly appreciated
joe chau
Hi @josephchau77
I would recommend you to use IPI (Inter Processor Communication) feature within the device rather than using a shared memory in case you are not looking to share big amount of data. IPI provides you a way to send messages between different cores and is not that hard to use.
Kind Regards
Ibai
Ibai
