fchpj
SDK 11.2 compiler mb-g++ or mb-gcc
In SDK 10.1, it seems that the compiler used to compile software platform and other projects is mb-gcc, and there is no problem while linking the xilkernel. But when I swtiched to SDK11.2, the compiler seems changed to mb-g++, and there is no problem when building software platform, but when I was building other projects, it had problem of linking the Xilkernel (-lxikernel is in). If I manually change the compiler to mb-gcc, it then compiles but I got the warning message like "conflict of compiler tools being used".
Anyone knows what's going on?
fchpj
dorau
How did you change the compiler manually ??
You should do it in "Software -> Software Platform Settings..."
Rgds,
Kai
fchpj
If you go to Project->Property, you can change it.
Actually I think I found I the issue. If you create a C++ project, the default compiler is g++, and gcc for a C project.
regards,
fchpj
