SDK 14.7 windows 8.1
I am working on a design using Plan ahead for Spartan3AN board, everything go well but when i try to program the bit file and the ELF file from the SDK it cant recognize the board however the Impact can recognize it easiy and program the bit file , i am working on windows 8.1
Re: SDK 14.7 windows 8.1
what is the error message you are getting
Thanks and Regards
Balkrishan
Here is the message
There is JTAG connection issue.
Please check the connection and see that the PC detects the device.
Praveen
