ranjithanih@gmail.com
SMBus & I2C difference
Is SMBUS IP is available in VIVADO ?
If no, can we use I2C xilinx ip instead of SMBUS ?
abhinayp
Hi ranjithanih@gmail.com
It is not available on Vivado, SMBus is a derivative of the I2C protocol, but there is something which an SMBus do.
What is the case in which you want to use the PS I2C?
Please go through the links below and let me know for queries if any.
https://www.xilinx.com/products/intellectual-property/1-8dyf-2509.html
https://www.xilinx.com/support/documentation/application_notes/xapp353.pdf
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Hi abhinayp,,
Thanks for the response.
I would want to access SMBUS slave which is placed on my fpga board.
Can i access SMBUS slave with XILINX I2C ?
abhinayp
Hi ranjithanih@gmail.com ,
Which FPGA are you using whether it is Zynq or ZynqMP?
As the protocol relies same you can communicate with SMBus.
Please let me know for further queries if any.
Best Regards
Abhinay PS
Thanks for the update.
I am using ZynqMPSOC.
I will communicate SMBUS slave with I2C IP as a master.
