SPI TO SPI/UART/GPI converter
Hi All,
I just started with FPGA design.
I would like to create a system for Artix 7 using Vivado and available IP cores(SPI, UART, GPIO, AXI interconnect)
The design implements bridge between SPI to the UART, GPIO, and another SPI(master to external peripherals). First SPI(AXI Quad SPI) is a slave to the external CPU and a master of the "AXI interconnect" and supposed to be connected to the slave port of "AXI interconnect", all other blocks are slaves to "AXI interconnect" and soppused to be connected to the master ports of "AXI interconnect". In such case CPU can address(send/recieve data) to/from all peripherals using biderectional SPI bus.
I'm not able to connects first SPI block to the slave interface, only to the master port of "AXI interconnect", but in this case even HDL wrapper can not be generated.
Could anyone suggest me a solution and what IPs/connection to use in order to make it work?
Attached simplified block diagramm of what I'm trying to do.
Thank you,
Andrey
u4223374
Advisor
Advisor
The Xilinx SPI controller is just a controller - it doesn't have the ability to translate SPI commands into AXI commands, act as an AXI master, etc. For that you will need to implement your own SPI-to-AXI IP, or stick a MicroBlaze in the middle that acts as an SPI slave and AXI master.
u4223374
Advisor
Advisor
Thank you for quick response. Understood.
Hi again,
I followed your advice and added Microblaze in to the design that should act as SPI slave and AXI bus master.
No problem with AXI bus, but SPI port seems can not be added to the Microblaze. Please correct me if i wrong.
