SWDT documentation unclear: External reset without internal reset?
The Zynq 7000 series system watchdog (SWDT) documentation on the zero-mode register (XWDTPS_ZMR_OFFSET) suggests that internal and external signals/resets can be invidivually enabled/disabled.
bit #0 (WDEN) Watchdog enable - if set, the watchdog is enabled and can generate any signals that are enabled.
bit #1 (RSTEN) Reset enable - if set, the watchdog will issue an internal reset when the counter reaches zero, if WDEN = 1.
I am concerned about the description of bit #0: "if set, the watchdog is enabled and can generate any signals that are enabled."
However, that seems not true; as I have enabled SWDT_RST_OUT on MIO pin 39 and WDEN=1 but I do not see this signal generated UNLESS I also enable bit #1 (RSTEN).
Figure 8.2 suggests that SWDT reset and SWDT_RST_OUT / MIO reset are tied together.
Can someone confirm or clarify this?
Leon.
