Simple AXI ip for remapping the address
Hi all,
I would like to have an ip which receive the address from PS and change the order of the address and pass it to a bram controller. How can I do that?
Should I take an AXI 4 full peripheral ip?
Re: Simple AXI ip for remapping the address
Thanks, I was able to do that by using a new memory mapped custom IP and it works.
Hi @rmirosan,
You should create custom IP for this purpose I guess.
Did you try using AXI full interconnect for reordering the address?
Praveen
I'm looking for something like this.  How did you do it?  Can you post the relevant code?  Thanks.
