08-27-2019 07:30 AM
I am attempting to implement multiple Xilinx MIPI DSI cores on an Artix 7 and use the Smartconnect to interface with all of the AXI-Lite inputs. MIPI requires the AXI-Lite interface to run at 200Mhz but i am unable to get the SmartConnect to pass timing at this clock speed. I have attempted to modify the Advanced Properties to add extra pipelining registers in the failing paths, however whenever i do this the changes are reverted as soon as I revalidate the block diagram, and any attempt at building produces the same timing results. How can i clean up the SmartConnect timing?
08-30-2019 02:47 PM
Hi @achafe ,
Which version of the tools are you using? If it is before 2019.1, I recommend using AXI Interconnect to connect to AXI-Lite interfaces.
Starting in 2019.1, SmartConnect has undergone a lot of improvements to make it more timing and area comparable to AXI Interconnect. Before that, it was pretty inefficient.
Deanna
08-30-2019 02:47 PM
Hi @achafe ,
Deanna
09-03-2019 05:55 AM
Thank you! I will try that!
Amy
