talvlad29
TLAST signal control
I am using Axi dma in my design to transfer data from ADC throughout FIFO (Stream Data FIFO IP) to DDR(S2MM only). I disabled packet mode for DMA because the FIFO is filled up by ADC samples continuously. TLAST output signal (m_axis_tlast) from FIFO to DMA was enabled but FIFO did not generated it until FIFO s_axis_tlad was managed (I temporary set s_axis_tlast FIFO every 1024 samples). I used a baremetal application (cortexr5_0) for testing my design and I received DMA error interrupt every transaction until added FIFO s_axis_tlast control in my design. My question is how/why I have to use TLAST signal in non-packet DMA mode. TLAST control does not make sense for me if I use ADC data stream.
Thank you,
Vladimir
Tags (3)
patocarr
Hi @talvlad29
  The AXI DMA supports the multi-channel feature and that's how the channels are separated: by a combination of TDEST and delimited with TLAST. This multi-channel feature may be obsoleted/removed at some point, because it was split into the new AXI MCDMA IP.
  In the one channel case, TLAST can be used to signal the end of a buffer and to force the utilization of a new block descriptor.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
patocarr
Hi @talvlad29
-Pat
talvlad29
Thank you for clarification.
