The maximum Baud uart 16550 rate can achieve
hi,i am using uart-16550 ip for connect to external ic. I saw pg143 describe that the baud rate can be generate for the axi clk ,the baud rate is equal to  axi clk dividered on factor 16. So when i provide 200M axi clk to the ip,the baud rate out  is 12.5Mbps.I do not know if I understand the right.
If I understand this correctly, what is the maximum speed supported by the ip.
Hi @caoshouqi,
For UART16550 the baud rate depends on the AXI CLK and the formula for the baud rate is
baud rate = AXI_CLK / (16*divisor)
most of the cases we calculate the divisor values based on the baudrate that we required and then we program the divisor latch register with divisor value.
Let us assume that we required a baud of 9600 then the divisor calculated as:
then load this divisor value in divisor latch registers to get the required baud rate.
Best Regards,
Srikanth
