manh_et2
Two uBlazes with connection FSL???
Does anyone have initiated a design with 2 uBlazes and the connection FSL between them?
Thank you all.
PS: I know we can do that upto 8 uBlazes with each bus FSL.
goran
Hi, With v7, each MicroBlaze has 16 incoming FSL and 16 outgoing FSL so you can connect to more than 8 now. Göran
manh_et2
Hi, I'm using EDK 9.1 so uB v6 with 8 FSL max, but it's not the problem.
But I've met certain difficulties when designing it. Have you done that?
goran
What kind of difficulties have you met?
Göran
manh_et2
Thank you Goran,
I've overcome this problem with minimum configuration. (No debug module)
Thank you anyway.
Message Edited by manh_et2 on 05-23-2008 09:25 AM
jagron
Here is a basic dual-core MB system.
https://wiki.ittc.ku.edu/ittc/Image:DualMicroblaze.zip
-Jason
