inaik
UARTlite
I am using UARTlite with Microblaze to display some data on the terminal. What is the difference between xil_printf and XUartLite_Send command? Is there anything visible on the terminal if we use XUartLite_Send command ? Can anyone provide me with a sample code.
Tags (3)
venui
xil_printf also uses same process to print data on the console you can use Xilinx examples available in github https://github.com/Xilinx/embeddedsw/tree/release-2019.1/XilinxProcessorIPLib/drivers/uartlite/examples
Venu
