Unable to get serial prints after using PMU api of xilpm library
Hi Folks,
I am trying to use xilpm api XPm_SystemShutdown (u32 type, u32 sybtype) in R5 application project.
The code builds successfully. However, I am unable to see output on serial terminal.
Steps Followed :
1. Created R5 application project (Hello World) in XSDK. After building, I am able to see prints on serial terminal.
2. Now, Added Xilpm in referenced bsp of R5 application project. Using xilpm api to reset the system.
However, I m not able to get serial prints which are written before using xilpm api.
Code Snippet :
int main() {
init_platform();
print("Hello World \n\r");
XPm_SystemShutdown(PMF_SHUTDOWN_TYPE_RESET, PMF_SHUTDOWN_SUBTYPE_SYSTEM);
cleanup_platform(),
return 0;
Referring below document to see usage of xilpm api
https://www.xilinx.com/support/documentation/user_guides/ug1199-zynq-power-management.pdf
The first argument (i.e. u 32 type) specified in this doc has two option : 1. PM_SHUTDOWN 2. PM_RESTART
Both these parameter is not found in pm api header files.
Please guide me on:
1. Usage of xilpm api so that expected results can be achieved.
2. The correct parameter to pass to first argument (i.e. u 32 type) of api.
3. I tried other api XPm_ForcePowerDown(NODE_RPU_0, REQUEST_ACK_NO). Here also the prints were not coming on serial.
Any suggestion would be appriciated.
Thanks & Regards,
Anjalee
Tags (2)
Can you please confirm that i the code is getting executed and in debug mode you are able to keep break point after helloworld print
Venu
