xifengw
Use 33 bits address with Microblaze
I need 33 bits width address with Microblaze's DP port in my design, but when I use 33bits address there will be some problems in 'xparameters.h' file.  what should I do?
The error information is "Description Resource Path Location Type
unsigned conversion from 'long long int' to 'UINTPTR' {aka 'unsigned int'} changes value from '4295032832' to '65536' [-Woverflow] xparameters.h /hello2_bsp/microblaze_0/include line 464 C/C++ Problem
xifengw
If the peripherals are not placed at addresses larger than 32 bits, there will be no compilation problems described above
calibra
Microblaze is a 32 bits processor.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
xifengw
But  there are 64 bits implement and it can be extended to 64GB or more in the MicroBlaze's wizard.
xifengw
