Using Xspi_Transfer I am getting delay for CS to go High after data transfer
Using Xspi_Transfer I am getting delay for CS to go High after data transfer i am get around 1 clk cycle delay how can i reduce the delay i want the cs to go high immediately after data transfer
Re: Using Xspi_Transfer I am getting delay for CS to go High after data transfer
@prashanth_makam
The SPI has a register controlling 4 different delays (Delay_Reg), but sadly for you, the delay between the last bit & CS deasserted is not in there / modifiable.
Then how can i reduce the Delay is there any register level code for SPI transfer
Hi Prashanth,
We don`t have any specific register to define the delay between the data transfer and CS to be deasserted.
It is always depends on when you are deasserting the CS after the data transfer.
Venu
The Chip select is controlled  by hardware i am not doing anything  below is the thing iam doing
Tx_Buffer[0]= 0xFF;
Tx_Buffer[1]= 0x01;
Tx_Buffer[2]= 0x02;
Tx_Buffer[3]= 0xAA;
XSpi_SetSlaveSelect(&SPI_SpiInstance,0x00000001);
XSpi_Transfer(&SPI_SpiInstance,Tx_Buffer ,Rx_Buffer,4);
XSpi_SetSlaveSelect(&SPI_SpiInstance,0x00000000);
@prashanth_makam
Are you sure you've set the CS in auto mode and did not left it in the default manual mode? If it is still the manual mode then a delay of ~1us can be expected.
I am using Xspi set slave select function before transferring the data and CS is controlled by master core logic
There is some standard after how much time we should start the data transfer, it should not be immediatly after asserting the CS.
Venu
