josephg
Using a testbench to test an AXI-Lite IP core
Hello!
I have created an AXI-Lite slave with the Vivado IP creator (using the "Create AXI4 Peripheral" option). As the generated code should simply be VHDL code, I thought about testing the IP core using a testbench.
Now I would like to read from one register where I modified the output ( instead of reg0 a constant is written to reg_data_out).
As far as I understand AXI, the following signals are needed:
axi_arvalid <= '1';
axi_araddr <= "0000"; -- as I would like to read reg0.
Sadly there is no output on axi_rdata.
The reset is set to 1 and the clock is also working.
What am I missing?
josephg
It is working now. I forgot to reset everything at the beginning.
bwiec
Can you post a screenshot showing the simulation of all the AXI Lite signals?
www.xilinx.com
josephg
Of course.
Additionally to the previously mentioned signals I set axi_rready to 1 because I am pretty sure this is necessary.
josephg
