akhilchandra
VGA Interface
I begin to inplement the VGA module in VHDL by Digilent Zynq Zybo board. so i need the document introducting VGA interface.
who have it pleased send me?
thank you very much!
yenigal
Check below links
https://eewiki.net/pages/viewpage.action?pageId=15925278
http://www.ece.ualberta.ca/~elliott/ee552/studentAppNotes/1998_w/Altera_UP1_Board_Map/vga.html
http://www.vhdlcodes.com/2010/11/display-on-vga-monitor-by-fpgavhdl-code.html
https://en.wikipedia.org/wiki/Video_Graphics_Array
Satish
yenigal
Check below links
Satish
akhilchandra
Thank You Very much Satish
akhilchandra
I came across this link here from the Zybo Base System Design
Where I felt which is much more in detail
http://www.xilinx.com/support/university/vivado/vivado-workshops/Vivado-embedded-design-flow-zynq.html
