Baffled_As_Ever
Vitis build - Gpio_DiscreteWrite
Using Vivado and Vitis 2020.2.
I've created a platform design on the microzed (zynq 7010) where I'm writing to couple of LED's via the PS and PL.
I'm able to control the LED using Xgpsio driver etc, and also the Xgpio driver.
However whenever I build the application, I get undefined reference 'Gpio_DiscreteWrite', though I've included the 'xgpio.h' in the application.
Any thought - suspect something's wrong in my build settings but help search generally shows the SDK setting not Vitis.
Any thoughts?
Tags (2)
ibaie
Hi @Baffled_As_Ever
It seems you already got the answer on a different board (see here), could you please mark this one also as solved so eventually others might find the right answer?
Ibai
