[Vivado 2019.2] Artix-7 ODDR component substitution for Zynq ?
I am working on a project migration from Spartan6 to Zynq UltraScale+.
The HDL code used for Spartan6 uses an ODDR (Output Double Data Rate Output Register with Set, Reset and Clock Enable) component (https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Vivado 2019.2's ODDR IP seems a totally different core, with just clock_in and clock_out:
What could I use in Zynq UltraScale+ architecture from Vivado 2019.2 IP repos as ODDR substitution ?
s.
Please reference the UltraScale Architecture Libraries Guide (UG974; v2019.2; pp 489-491).
That looks like a bug in the IP catalog.  Look in Tools=>Language Templates =><family>=>I/O Components=>Output DDR Register and you will see the correct instantiation.  For VHDL, it looks like this:
   ODDR_inst : ODDR
   generic map(
      DDR_CLK_EDGE => "OPPOSITE_EDGE", -- "OPPOSITE_EDGE" or "SAME_EDGE"
      INIT => '0',   -- Initial value for Q port ('1' or '0')
      SRTYPE => "SYNC") -- Reset Type ("ASYNC" or "SYNC")
   port map (
      Q => Q,   -- 1-bit DDR output
      C => C,    -- 1-bit clock input
      CE => CE,  -- 1-bit clock enable input
      D1 => D1,  -- 1-bit data input (positive edge)
      D2 => D2,  -- 1-bit data input (negative edge)
      R => R,    -- 1-bit reset input
      S => S     -- 1-bit set input
s.
@bruce_karaffa, not really a bug.
The problem (if we can call it as such) is that the libraries and IP cores changes from arch to arch.
