Warnings on vivado (for zybo boards)
i have recently install webpack version and i enormous amount of warning. few of these are as follows,
i have also attached my project so  could anyone  help me out on this ?
I am using zybo  board but i get warnings on arty files!!
  • [Board 49-26] cannot add Board Part digilentinc.com:arty-s7-25:part0:1.0 available at C:/Xilinx/Vivado/2017.4/data/boards/board_files/arty-s7-25/E.0/board.xml as part xc7s25csga324-1 specified in board_part file is either invalid or not available
  • set_property -dict [list CONFIG.C_ALL_INPUTS {0} CONFIG.GPIO_BOARD_INTERFACE {leds_4bits}] [get_bd_cells axi_gpio_0]
  • [Synth 8-350] instance 'proc_sys_reset_0' of module 'design_1_proc_sys_reset_0_0' requires 10 connections, but only 7 given ["G:/ZyboCodes/IndividualModules/LED_PL/LED_PL.srcs/sources_1/bd/design_1/synth/design_1.v":166]
thank you
Voyager
Voyager
Re: Warnings on vivado (for zybo boards)
The most likely issue is that the Zybo board files are not included in the WebPack release that you installed.
Check out the following link:
https://reference.digilentinc.com/reference/software/vivado/board-files
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
