Web server creation using Zedboard
Board Specifications:
Zedboard (xc7z020clg484-1)
Requested support for web server application using Ethernet interface/Wifi Pmod with Soc Block design with Zed board.
klumsde
HI ashadevi.d@rediff.com
take a look here
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
Keith
dpaul24
ashadevi.d@rediff.com,
What have you tried to do yourself? Can you show us?
What is the problem you are facing?
Moreover there are many project ideas available, did you try to search the Web?
Replace the uBlaze by Zynq > https://www.xilinx.com/support/documentation/application_notes/xapp433.pdf
Demo eval core (I don't know whats inside it) > http://www.webphyfpga.com/Downloads.html
Something from Digilent > https://forum.digilentinc.com/topic/3204-zybo-webserver/
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
ericv
Hi ashadevi.d@rediff.com
we have a web-server demo running on the Zedboard  (all source code & SDK project) based on the lwIP server that is included in our BSP package.
You can get it by requesting the BSP package at
www.code-time.com
