a.turowski2
What A53 core IP revision is used in ZynqMP
Hi all,
Can you tell me which exactly A53 core revision is used in ZynqMP chips please? I mean the core revision as defined by ARM (r0p0, r0p1, r0p2, r0p3, r0p4)
Adam
pratham
@a.turowski2 r0p2
-Pratham
pratham
@a.turowski2 r0p2
-Pratham
