What is the PL fabric clock?
As  described by the title
1.what is the PL fabric clock(FCLK_CLK0...)?
2.what does it work for?
Voyager
Voyager
Re: What is the PL fabric clock?
Hi @chris0622
Those clocks are generated by the PS and can be used by the PL.
Have a look at page 699 of this document.
Voyager
Voyager
Hi @chris0622
so the higher the fabric clock is , the faster the IP I created works on SDK is . right?
Thank you!
Voyager
Voyager
Hi @chris0622
If you increase the clock frequency and the design passes timing (no violations) then the IP core will work faster on the hardware.
