anmol_8496
XAPP1078 Zynq FSBL for AMP error with invalid command name "xget_processor_name" in VIVADO2018.2
stephenm
Not a lot of info here.
Does the HDF file used here contain a processor? How did you create the HDF.
akash.o
Even I'm facing similar issue with Vivado17.2. processor used is zynq zc702 when I'm creating fsbl it is fine. but according to xapp1078 I'm unable to create fsbl_amp getting error as mentioned above. I have tried downloading xapp1078/1079 with versions for vivado 14.4. Still unable to create fsbl_amp and core1_amp_bsp
Please reply. Thanks in advance.
