pietro_dcs
XLAT Axi stream to Memory map
Good morning
I need the simplest basic way of translating the flow through the AXI stream in the memory mapped.
I do not want to have any DMA or fifo on the scene. I need the source code of a simple translation.
Is there a suggestion where do I find such code?
Thank You
Pietro
Tags (3)
abouassi
Hi @pietro_dcs,
You are welcome.
No, not AFAIK.
Abdallah
abouassi
Hi @pietro_dcs,
Does AXI_Streaming_FIFO fulfil your need?
If no, please try to elaborate.
Abdallah
pietro_dcs
Good morning
Thank You for the suggestion.
It is the most similar component for my need. For now I will use.
I would like to have a simpler solution in my hand to customise as needed.
If You have a source accessible solution let me know
Thank You
Pietro
abouassi
Hi @pietro_dcs,
You are welcome.
No, not AFAIK.
Abdallah
