tmaintz
Xilinx FFT "Event_Frame_Started" as PL-PS Interrupt to Zynq PS
Hi there,
long story short: Is there something special to connect a signal (which is '1' for 1 FPGA clock cycle) as an interrupt to the Zynq PS?
Background information:
I would like to transfer some data from PS to PL via DMA when a FFT starts to calculate data. I've connected the FFT output "event_frame_started" via a concat element to the Zynq IRQ_F2P Interrupt input (see attachment). Synthesis works fine, no error messages.
I can see the correct behaviour of the "event_frame_started" by an ILA core. But there is no interrupt executed in the PS. Therefore I guess that the PL interrupt might not be recognized by the PS.
This is the sourcecode of the PS part to connect the interrupt signals to a callback function (color names in the printf are macros for terminal output):
int Zynq_Register_ISR(XScuGic* ISR_Controller_ptr, unsigned int device_intr_address, Xil_InterruptHandler ISR_Ptr, void *ISR_argument)
if ( ISR_Controller_ptr == NULL ) return XST_FAILURE;
    if (XScuGic_Connect(ISR_Controller_ptr,
            ISR_Ptr,
            ISR_argument) == XST_SUCCESS)
        XScuGic_Enable(ISR_Controller_ptr, device_intr_address);
        xil_printf("ISR Address %p " GRN " ENABLED" RESET "\n\r",device_intr_address);
    else
        xil_printf("ISR Address %p " RED " FAILED" RESET "\n\r",device_intr_address);
        return XST_FAILURE;
    return XST_SUCCESS;
int SetUpInterruptSystem(XScuGic *XScuGicInstantePtr)
    Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT, (Xil_ExceptionHandler) XScuGic_InterruptHandler, XScuGicInstantePtr);
    Xil_ExceptionEnable(); // enable ISR in ARM
    return XST_SUCCESS;
int InitializeInterruptSystem(int deviceID )
    if((GicConfig = XScuGic_LookupConfig(deviceID)) == NULL)
        return XST_FAILURE;
    int result = XScuGic_CfgInitialize(&InterruptController, GicConfig, GicConfig->CpuBaseAddress);
    if(result != XST_SUCCESS)
        return XST_FAILURE;
    if (SetUpInterruptSystem(&InterruptController) != XST_SUCCESS)
        return XST_FAILURE;
    return XST_SUCCESS;
} // called by int register_ISR()
{ if (Zynq_Register_ISR(ISR_Controller_ptr, XPAR_FABRIC_XFFT_0_EVENT_FRAME_STARTED_INTR, (Xil_InterruptHandler)FFT_Started_ISR, NULL) == XST_FAILURE) return XST_FAILURE;
return XST_SUCCESS;
} // callback function of the event started interrupt void FFT_Started_ISR(void* arg) { xil_printf("%s\n\r",__func__); Xil_Out32( XPAR_AXI_DMA_1_BASEADDR + MM2S_SourceAddress, (unsigned int)start_address ); Xil_Out32( XPAR_AXI_DMA_1_BASEADDR + MM2S_Length, length); }
int main(void)
init_platform();
    ps7_post_config();
if(InitializeInterruptSystem( XPAR_PS7_SCUGIC_0_DEVICE_ID ) == XST_SUCCESS)
        xil_printf(RED "ISR System Initialized\n\r" RESET);
    else
        xil_printf(GRN "ISR System ERROR\n\r" RESET);
    if(register_ISR() != XST_SUCCESS)
        xil_printf(RED "DMA_Init_with_ISR\tFAILED\n\r" RESET);
while(1) {}
return 0;
Thanks for any replies!
If you need further information don't hesistate ;)
Greetings,
Thomas
tmaintz
The AXI Interrupt Controler is the answer ;)
Setting this Core to level detect mode helps me out.
Sorry for answering my own posts!
Greetings,
Thomas
tmaintz
Here's the ILA output connected to the FFT Core output signals.
As you can see the "event_frame_started" is '1' for 1 FPGA cycle. Is that too short for the PS to detect?
tmaintz
I didn't know about the AXI Interrupt Controller. After a few mistakes with the core I give it some more tries. Nevertheless this core didn't generated an interrupt on the single sided output for the Zynq PL-PS IRq input. I guess this is because of a misconfiguration.
I'll keep you updated.
tmaintz
Greetings,
Thomas
