sha@hys
Xilinx XPS error plb_v46_0 - must have atleast 1 master assigned
Hi ,
I am new to microblaze. I am having spartan 6 FPGA and wants to configure microblaze with spi peripheral . I am using XPS for it and got an error as below.
ERROR:EDK:4119 - IPNAME: plb_v46, INSTANCE: plb_v46_0 - must have atleast 1
master assigned
I am trying to solve this for past 1 day and could'nt. Kindly help.
thanks in advance
Tags (3)
pvenugo
The issue looks like the connection to PLB is left open.
Refer to the attached MHS file for connections.
Praveen
sha@hys
Sir ,
I am still facing issues in implementation.If you have an .xmp project of XPS using SPI core could you please send me that?
