ZC702 Uboot changes to load image.ub from SPI flash
Hi All,
I am able to flash BOOT.BIN to ZC702 spi flash using sf commands. But when I power cycle the board and try to boot it, its hanging at uboot command prompt. I believe U-boot needs some command defined to load image.ub from spi flash to RAM and execute kernel.
Can you tell me SPI address to load image.ub?
Also where should I load image.ub from flash using sf read to RAM? RAM location to read image.ub from spi flash.
Shyam
Hi @shyamthella ,
Could you please share your bootargs of ZC702 board?
you can use printenv command
e.g. printenv bootargs
You need to add boot args as shown below if you are uisng jffs2 filesystem,
earlycon clk_ignore_unused root=mtd:jffs2 rw rootfstype=jffs2
if you are using normal initramfs then,
earlycon console=ttyPS0,115200 clk_ignore_unused
Best Regards
Kranthi
