ajasan
ZC706 PCIe root complex example design with FMC
Hi, Can anyone help to locate the source file directory for PCIe root complex design for ZC706 eval board with FMC card?
It is mentioned as zynq_rc_x4g1_example_design.zip in the user guide of the design.
Asan.
umamahe
I did not find any exact source file directory for PCIe root complex design for ZC706 eval board with FMC card. The below is some related information. Please check whether it is useful for you
For 7-series FPGA family devices “PCIE Example Designs” concepts are described in the below IP document http://www.xilinx.com/support/documentation/ip_documentation/pcie_7x/v3_1/pg054-7series-pcie.pdf from page 263 onwards. Refer “Test Benches” topic from page301 onwards. Source code for the Root Port Model is included to provide the model for a starting point for your test bench. Refer this to understand concepts.
Please refer http://www.xilinx.com/support/documentation/application_notes/xapp1171-pcie-central-dma-subsystem.pdf .  This application note demonstrates a Vivado® Design Suite subsystem for endpoint-initiated Direct Memory Access (DMA) data transfers through PCI Express®. The provided subsystems target the following devices to initiate data transfers between DDR3 memory and an externally connected PCI Express Root Complex: • Zynq®-7000 ZC706 device. Check this application note is suitable for your requirement.
You can download design files zip file for this application note (XAPP1171.zip) from the following link https://secure.xilinx.com/webreg/clickthrough.do?cid=344579&license=RefDesLicense&filename=xapp1171.zip&languageID=1 after registration.
FYI:
The information about base board support of different FMC cards can be found in below links
http://www.xilinx.com/products/boards-and-kits/fmc-cards.html
http://www.xilinx.com/products/boards-and-kits/fmc-cards-and-accessories.html
Also refer http://www.xilinx.com/products/boards-and-kits/1-3y8uxi.html
