ZYNQ AXI master port
Hi all,
in my block design I connectd with an AXI Interconnect the AXI master port of my ZYNQ, that is M_AXI_GP0, with the AXI slave port S00_AXI of an AXI slave created making use of  "Tools/Create and PAckage new IP". I started by a data width of 32 bit and it is ok, but now I modify my AXI slave to write and read 64-bit data (C_S00_AXI_DATA_WIDTH : integer := 64).
My question is: how can I do to change data size at my PS side?
I thought it was simple, but can't find an AXI master port with 64 data with, that seems a little strange... Otherwise, can you suggest me some workaround?
Thanks a lot in advance.
Alessandra
Tags (3)
HI @ale11286
Refer to the Zynq-7000 TRM (UG585).  The M_AXI_GP ports are General Purpose 32-bit AXI Master.
So you cannot change its data width
The workaround would be to use an AXI interconnect to do the connection between the 32-bit interface of the zynq and the 64-bit interface of your IP
Florent
HI @ale11286
Florent
