[Zedboard] AXI-GPIO interrupt not working
I have the following hardware:
For the software, the interrupt part, I copied from a previous project where I had a custom IP generating the interrupt source so I thought it would be copying and pasting. Here is the software:
#include "xparameters.h"
#include "xil_printf.h"
#include "xgpio.h"
#include "xuartps.h"
#include "xscugic.h"
#define BUTTONS_channel		1
#define BUTTONS_AXI_ID		XPAR_AXI_GPIO_0_DEVICE_ID
#define SWITCHES_channel	1
#define SWITCHES_AXI_ID		XPAR_AXI_GPIO_1_DEVICE_ID
#define LEDS_channel		1
#define LEDS_AXI_ID			XPAR_AXI_GPIO_2_DEVICE_ID
#define UART_DEVICE_ID      XPAR_XUARTPS_0_DEVICE_ID
#define INTC_DEVICE_ID 		XPAR_PS7_SCUGIC_0_DEVICE_ID
#define INT_PushButtons		61
#define IDLE		0
#define STOP 		1
#define FORWARD 	16
#define BACKWARDS 	2
#define LEFT 		4
#define RIGHT 		8
XGpio BTNS, STWS, LEDS;
XUartPs Uart_Ps;		/* The instance of the UART Driver */
XUartPs_Config *Config;
static XScuGic INTCInst;
u32 buttons=0, switches=0;
u8 stop[] = "STOP 0\r";
u8 forward[] = "GO 15 15\r";
u8 backwards[] = "GO FFEC FFEC\r";	//Two's complement -20=FFEC
u8 left[] = "GO FFEC 15\r";
u8 right[] = "GO 15 FFEC\r";
static int IntcInitFunction(u16 DeviceId);
int InterruptSystemSetup(XScuGic *XScuGicInstancePtr);
void PushButtons_Intr_Handler(void *data);
void sendUART(u8* message, int len);
int main(void)
	int Status;
	// Initializes AXI-GPIO_0 (Touch buttons)
	Status = XGpio_Initialize(&BTNS, BUTTONS_AXI_ID);
	if (Status != XST_SUCCESS)
		xil_printf("Buttons error\n");
		return XST_FAILURE;
	// Initializes AXI-GPIO_1 (Switches)
	Status = XGpio_Initialize(&STWS, SWITCHES_AXI_ID);
		xil_printf("Switches error\n");
		return XST_FAILURE;
	// Initializes AXI-GPIO_2 (LEDs)
	Status = XGpio_Initialize(&LEDS, LEDS_AXI_ID);
		xil_printf("LEDs error\n");
		return XST_FAILURE;
	// Sets AXI-GPIO's directions,
	XGpio_SetDataDirection(&BTNS, BUTTONS_channel, 0xFF);	// Input
	XGpio_SetDataDirection(&STWS, SWITCHES_channel, 0xFF);	// Input
	XGpio_SetDataDirection(&LEDS, LEDS_channel, 0x00);		// Output
	 * Initialize the UART driver so that it's ready to use
	 * Look up the configuration in the config table and then initialize it.
	Config = XUartPs_LookupConfig(UART_DEVICE_ID);
	if (NULL == Config) {
		return XST_FAILURE;
	Status = XUartPs_CfgInitialize(&Uart_Ps, Config, Config->BaseAddress);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	XUartPs_SetBaudRate(&Uart_Ps, 115200);
	// Initializes interruptions.
	Status = IntcInitFunction(INTC_DEVICE_ID);
	while(1)
	/*	buttons = XGpio_DiscreteRead(&BTNS, BUTTONS_channel);
		switch(buttons)
			case STOP:
				XGpio_DiscreteWrite(&LEDS, LEDS_channel, 1);	// LD0.
				sendUART(stop, sizeof(stop));
				break;
			case FORWARD:
				XGpio_DiscreteWrite(&LEDS, LEDS_channel, 2);	// LD1.
				sendUART(forward, sizeof(forward));
				break;
			case BACKWARDS:
				XGpio_DiscreteWrite(&LEDS, LEDS_channel, 4);	// LD2.
				sendUART(backwards, sizeof(backwards));
				break;
			case LEFT:
				XGpio_DiscreteWrite(&LEDS, LEDS_channel, 8);	// LD3.
				sendUART(left, sizeof(left));
				break;
			case RIGHT:
				XGpio_DiscreteWrite(&LEDS, LEDS_channel, 16);	// LD4.
				sendUART(right, sizeof(right));
				break;
	return 0;
	int SentCount = 0;
	while (SentCount < (len-1))
		/* Transmit the data */
		SentCount += XUartPs_Send(&Uart_Ps, &message[SentCount], 1);
	int Status;
	XScuGic_Config *IntcConfig;
	// Interrupt controller initialization
	IntcConfig = XScuGic_LookupConfig(DeviceId);
	Status = XScuGic_CfgInitialize(&INTCInst, IntcConfig, IntcConfig->CpuBaseAddress);
	if(Status != XST_SUCCESS) return XST_FAILURE;
	// Call to interrupt setup
	Status = InterruptSystemSetup(&INTCInst);
	XScuGic_SetPriorityTriggerType(&INTCInst, INT_PushButtons, 0, 3);	//Max priority, rising edge.
	Status = XScuGic_Connect(&INTCInst,	INT_PushButtons, (Xil_ExceptionHandler)PushButtons_Intr_Handler, (void *) 0);
	XScuGic_Enable(&INTCInst, INT_PushButtons);
	return XST_SUCCESS;
	 * Initialize the interrupt controller driver so that it is ready to use.
	Xil_ExceptionInit();
	// Enable interrupt
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
			 	 	 	 	 	 (Xil_ExceptionHandler)XScuGic_InterruptHandler,
	Xil_ExceptionEnable();
	return XST_SUCCESS;
	switch(buttons)
		case STOP:
			break;
		case FORWARD:
			break;
		case BACKWARDS:
			break;
		case LEFT:
			break;
		case RIGHT:
			break;
If I don't use the interrupt, it works but i want to avoid doing it in the while loop. Have I missed something or not configured a register?
Thank you for the help.
Re: [Zedboard] AXI-GPIO interrupt not working
Hi @aripod
yes.. You need to clear the interupt...
Call this function... XGpio_InterruptClear(GpioInstance,InterptMask);
Thank you
Madhu
Hi @aripod
You haven't enabled the interrupts in AXI_GPIO...
Use these functions
	 * Enable the GPIO channel interrupts so that push button can be
	 * detected and enable interrupts for the GPIO device
	XGpio_InterruptEnable(InstancePtr, IntrMask);
	XGpio_InterruptGlobalEnable(InstancePtr);
Go through the file xgpio_intr_tapp_example.c (located at <xilinx_instal_folder>\SDK\2017.1\data\embeddedsw\XilinxProcessorIPLib\drivers\gpio_v4_3\examples)
Madhu
Hello @madhu.mami60,
Thank you for your help. I checked the example and compared it with my code and I was only missing the two lines that you said. I added them just before the while loop, but I am still not getting the interruption when I press a push button.
#include "xgpio.h"
#define IDLE		0
#define STOP 		1
#define FORWARD 	16
#define BACKWARDS 	2
#define LEFT 		4
#define RIGHT 		8
u32 buttons=0, switches=0, IntrMask;
int main(void)
	int Status;
	u8 recv[256] = {0};
	u32 nbytes;
		return XST_FAILURE;
		return XST_FAILURE;
		return XST_FAILURE;
	// Enable AXI-GPIO's interruption.
	XGpio_InterruptEnable(&BTNS, IntrMask);
	XGpio_InterruptGlobalEnable(&BTNS);
		return XST_FAILURE;
		return XST_FAILURE;
	while(1)
		//XUartPs_Recv(&Uart_Ps, recv, nbytes);	//To test if Tx and Rx on the PMOD were working.
		/*switch(buttons)
			case STOP:
				break;
			case FORWARD:
				break;
			case BACKWARDS:
				break;
			case LEFT:
				break;
			case RIGHT:
				break;
	return 0;
	int SentCount = 0;
	XUartPs_Send(&Uart_Ps, message, len-1);
	/*while (SentCount < (len-1))
		// Transmit the data
	int Status;
	return XST_SUCCESS;
	// Enable interrupt
	return XST_SUCCESS;
	switch(buttons)
		case STOP:
			break;
		case FORWARD:
			break;
		case BACKWARDS:
			break;
		case LEFT:
			break;
		case RIGHT:
			break;
Should I call XGpio_InterruptEnable and XGpio_InterruptGlobalEnable somewhere else?
Thank you.
Hi @aripod
You are missing the "IntrMask" variable assignment. No mash value assigned. Assign the mask value to which port you want get interrupt.
And, in your main function, do nothing in while(1) loop. Add comment to this also
As you continuously performing a read operation, the interrupt may clear.
Madhu
Hello @madhu.mami60
Sorry for the dumb question. By port you mean which AXI-IP? Or as I have 5 buttons, which button I want get interrupt?
Thank you!
I believe you meant I have to do something similar when I assign if they are input or ouput: XGpio_SetDataDirection(&BTNS, BUTTONS_channel, 0xFF); Right? So for the IntrMask it should also be 0xFF if I am not mistaken.
Yes...
Hello @madhu.mami60. I have just tested this with XGpio_InterruptEnable(&BTNS, 0xFF);. The interruption happened but only once. Do I need to clear something before leaving the interrupt handler function?
Thank you again for your help.
Hi @aripod
Thank you
Madhu
Not it is working. Thank you very much for your big help!
Ok, now the interruptions works but the uart does not output anything else. Can they be related?
Hi @aripod
1) Check the Uart Terminal baudrate in your pc... Both should be 115200 as you set.
2) Check the Rx and Tx connections are proper,
3) Set the operation mode
XUartPs_SetOperMode(&Uart_PS, XUARTPS_OPER_MODE_NORMAL);
4)
	int SentCount = 0;
	XUartPs_Send(&Uart_Ps, message, len); //Send full lentgh. Why -1??
Madhu
Hi @madhu.mami60,
I also tested the UART through the PMOD and this is why I was not seeing anything on the terminal. Thank you for the help again.
Once try simple Hello world.
Can post the complete code again please?
I don't know how to clear the interrupt. I'm adding at the end of the GpioHandler the following line:
XGpio_InterruptClear(data,IntrMask);
It doens't work :(
I'm also having trouble replicating the solution. My code does not resume the stack after the handler function is called and I am calling XGpio_InterruptClear(data,IntrMask);.
