Zynq Timer and UART interrupt examples will not work together
Vivado 2014.3
Win 7, 64-bit sp1
microZed
Core0, UART1 & Timer
Trying to use both interrupt examples and the UART interrupt will stop working some time during the Timer interrupt example setup.
Both work stand alone.
Thanks in advance,
Re: Zynq Timer and UART interrupt examples will not work together
Thanks for the repy muzzafer, turns out that I was redefining the struct for the type XScuGic when I initialized the second interrupt. I think I was assigning the GIC in a different spot in memory so the previous interrupt no longer worked.
If I change the order in which the examples are started, the last device is always the one enabled.
Are you sure you are enabling both interrupts ? The fact that the last one gets started stays enabled suggests that the enable code is disabling all other interrupts. Check for a bitfield where you set multiple bits to enable multiple interrupts. Also make sure that you understand the priority of interrupts and what happens if you get the higher priority interrupt while you are servicing the lower priority one. Nested interrupts are difficult to test & debug.
Dear jeff,
I met the same problem.Could please tell me how you did in detail?
Thanks in advance
I am  trying to implement two interrupt, one with timer and uart
could you share your code for reference
