Zynq UART Baud Rate Limit and IP Cores
I'm trying to design a system which has to communicate with 4,125,000 bps (~4 Mbps) UART baud rate. I could not realize a Zynq model which has a processor supporting this UART requirement.
I also investigated some IP Cores for FPGA part of Zynq which promotes 4 Mbps however i could not find again. My question is that is there a limit of baud rate on Zynq models and if it is, is it possible to write a UART Vhdl code, which supports this baud rate?
My another question is about AXI protocol. Is there a baudrate limit about AXI on Zynq?
Thank you.
Tags (2)
Advisor
Advisor
There is a limit for the PS-PL AXI ports, but it's high - 250MHz 32-bit for the general-purpose interfaces and 250MHz 64-bit for the high-performance ones. This is not going to be the limiting factor for your UART.
You should definitely be able to write a UART operating at 4.125MHz in VHDL or Verilog. Even with a very simple clock divider, you can get to 4.166MHz by dividing a 100MHz clock by 24 - and this results in a clock error of about 1%. UARTs can normally tolerate 5% easily, so 1% should be fine.
Obviously signal quality may be an issue if you're doing this over long distances, but for short range it'll be fine.
Advisor
Advisor
I need to configure this UART communication with an error that must be less than 10^(-8). Can both 4Mbs baud rate and this error rate be obtained, in your opinion?
I am new to the ZYNQ, but I am  a HW EE
To your question...
It depends very much on the line driver you are using.
For instance RS422 can do 4Mbit  easy but RS232 probably no more than a few foot of cable length.
KB
My interface is RS485 so i think it will be possible. Thank you.
4,125,000 bps should be no problem using an AXI_UART (not lite) and a good RS-422/RS-485 transceiver.
I do a similar speed for a custom sensing application.
If it were me, I would clock the AXI bus at 66MHZ (66,000,000), hang an AXI_UART on the AXI Bus, and then set the MSB:LSB Baud rate divider to 1.  That will give you 66,000,000 / 16 / 1 = 4,125,000
I don't have Vivado on the machine I'm writing this on, but I think you'll need to do one of two things in order to clock the AXI Bus at 66,000,000
A) Use a Clock Wiz to generate that freq.
B) Use an external oscillator (probably what I would do) and bring it in to a clock capable I/O pin.  Use that clock to drive the AXI bus clock.
Good luck with your design,
Ben
Can you tell me the full name of the "AXI UART"?
Is that an IP core?
I only find AXI_UARTLite and AXI Uart16550.
